Mitsubishi RMD-50A Kenza Cloud Gateway
Introducing Mitsubishi RMD-50A Kenza Cloud Gateway
Kenza Cloud is a powerful cloud-based platform for managing and monitoring CITY MULTI VRF, P-Series, and M-Series commercial HVAC systems remotely. It is accessible through the link www.kenzacloud.com
RMD-50A configuration
What is The RMD-50A, And Why It’s Important Today
The RMD-50A is the dedicated bridge that connects your Mitsubishi Electric VRF system's M-NET network directly to the Kenza Cloud platform. A PC, tablet, smartphone, or other terminal device with a connection to the Internet is required to use the RMD-50A.
The RMD-50A is a scalable gateway that allows monitoring and control of up to 50 indoor and 50 outdoor units, making it ideal for multi-zone or growing commercial environments.
It provides advanced remote analytics, including maintenance tool file downloads for detailed system data, refrigerant level checks, and installation verification for CITY MULTI R2-Series branch boxes.
Designed for easy setup, it supports versatile low-voltage power options and connects directly to the M‑NET communication cable, streamlining installation in commercial mechanical rooms while reducing service calls and system downtime.
Who is RMD-50A for: As buildings become smarter and more connected, facility managers and contractors need efficient ways to monitor, control, and analyze their HVAC systems remotely.
Use Cases
  • Office Complex: A facility manager oversees 40 indoor units and 10 outdoor units from one RMD-50A, adjusting schedules and viewing temperature trends remotely
  • Hotel Chain: Each property installs an RMD-50A to monitor refrigerant levels and receive automatic maintenance alerts via Kenza Cloud.
  • Retail Network: Stores in remote areas use RMD-50A gateways to diagnose HVAC issues before dispatching a technician, reducing travel costs.
Technical Specs Snapshot
Specification
Detail
Supported Units
50 indoor + 50 outdoor
Power Supply
TB1: 24 VAC ± 10% (50/60 Hz) Rated power: Minimum 5 VA and maximum 25 VA Rated current: Minimum 0.2 A and maximum 1.1 A or 24 VDC ± 10%; Minimum 10 W and maximum 30 W
TB2: 17–30 VDC (powered from the M-NET)
Communication
M-NET (TB2 terminals)
Network Interface
Ethernet (100BASE-TX)
Operating Temp
+14 °F to +131 °F
Power Consumption
7.5 W
Dimensions
6.83 × 5.52 × 2.32 Inches
Weight
~1.10 Lbs.
Mounting
Control cabinet / DIN rail
Idea
Check out the article here for more information on HVAC maintenance.
InfoContact our HVAC Controls Engineering team for assistance with custom HVAC control solutions or learn more here.
