Airzone's Aidoo Wi-Fi with Fujitsu Units
Fujitsu have a number of wireless controllers. See this link for some of the wireless interfaces.
However, there are other alternatives for the controlling of a Fujitsu unit via a third-party wireless interface. One of the common alternatives is to use Airzone Aidoo Wi-Fi or Aidoo Z-Wave Plus wireless interface (see this article for other Airzone's interfaces).
See below image illustrating Airzone Aidoo and the wired controller connection to an AC unit.
For Aidoo Wi-Fi there are 2 common wireless interface that are compatible with most Fujitsu indoor units (either Floor/Ceiling, Split, Console, Ducted unit, or Cassette):
  1. AZAI6WSCFUJ
Important: This device is only compatible with 3 wires protocol Fujitsu units equipped with the UTY-RNNxM or UTY-RSNxM thermostats. The unit controller must remain working in parallel with your Aidoo as “Master” mode.
  1. AZAI6WSCFU2
The connection for these Wi-Fi interfaces to the indoor units and configuring them to connect to the Wi-Fi router should be straightforward.
One advantage for the Aidoo Wi-Fi interfaces (check AZAI6WSPMEL for Mitsubishi units) is that they support dual Wi-Fi communication unlike other wireless interfaces which only supports 2.4GHz alone. Again, there is an option for BACnet/Modbus integration.
Good to note, there some instances for some of the Fujitsu indoor units where an accessory may be required to integrate the Aidoo Wi-Fi interfaces (see table for sample units that require accessories).
See below table for compatibility table for some of the Fujitsu units:
Indoor Unit
AZAI6WSCFUJ
AZAI6WSCFU2
ACCESSORY
ASU07RLF1
YES
UTY-WIFI
ASY25UI-MI
YES
UTY-XCBXZ1, UTY-WIFI
ASUA12TLAV1
YES
ASU18RLF
YES
UTY-WIFI
AGUA9TLAV2
YES
ABUA24TLAV2
YES
ABYA45GATH
YES
ACUH18LUAS1
YES
ACY125UIA
YES
AAUA48TLAV
YES
ACY100UIA-LB
YES
ASYG07LUCA
YES
UTY-TWBXF, UTY-WIFI
ASY20MI-LMC
YES
UTY-XCBXZ2, UTY-WIFI
Contact our HVAC Controls Engineering team for any assistance with HVAC wireless controls or other HVAC control solutions.
