Automation and intergration of home systems with HVAC units and controls is key for convenience, comfort and energy savings.
Aidoo Wireless Interfaces allow old and new HVAC units to be connected and integrated with home automation systems.
1. Aidoo Pro Inverter/VRF Controller
2. Aidoo Pro Fan coil
Aidoo AZAI6WSPFAN manages and integrates fancoil units remotely from the Cloud online control with the “Airzone Cloud” App (available for iOS and Android). It is externally powered at 110 / 230 Vac.
3. Aidoo KNX Controller
Aidoo AirZone AZAI6KNXDA0 device for the management and integration of indoor units in KNX TP-1 control systems. Inverter/VRF AC unit can be controlled by using any of the other devices connected within the KNX system.
4. Inverter/VRF Wi-Fi Controller
Airzone's Aidoo
AZAI6WSCDKB is
the best Inverter/VRF Wi-Fi controller in the market today, combining seamless integration with smart technologies. With the app, the adapter provides remote control and monitoring of S21 indoor units .
5. Aidoo Z‑Wave Plus
The z-Wave Plus interface transforms an inverter/VRF into a Z‑Wave device.
This adapter is compatible with all the controllers that hold the Z‑Wave and Z‑Wave Plus certifications. It acts as an independent repeater to improve network reliability as well.
Check out the article
here with more information on Z-Wave technology.
Below is how they compare.
| Pro Inverter VRF | Wi-Fi Inverter VRF | Pro Fan Coil | KNX Inverter VRF | Z-Wave Plus Inverter VRF |
Unit Control | Communication Gateway | Communication Gateway | 0-10V/ 3 Speeds | Communication Gateway | Communication Gateway |
Connectivity | Wi-Fi Dual Band 2.4/5 GHz | Wi-Fi Band 2.4 GHz | Wi-Fi Dual Band 2.4/5 GHz | KNX | Z-Wave Plus |
Control/ Settings | Airzone Cloud App | Airzone Cloud App | Airzone Cloud App | ETS | Z-Wave |
App Available? | Yes | Yes | Yes |
Voice Control | Yes | Yes | Yes |
Cloud API | Yes | Yes | Yes |
Power Source | 12 VDC (External) | 12 VDC (Indoor Unit/ External) | 220 VAC | Indoor Unit& KNX Network | 12 VDC (Indoor Unit/ External) |
RS485 Integration | Modbus& Bacnet MS/TP | Modbus | Modbus& Bacnet MS/TP |
| Modbus |
Here are more Wi-Fi Control Interfaces or modules used with other HVAC Indoor Units.
