Venstar Wireless Controls and Accessories
Venstar is one of the leading HVAC brands in the market that offers a wide range of thermostats and accessories for different applications depending on user needs.
Lets have a look at the different thermostats as well as the available accessories.
ColorTouch Thermostats
Ventar colortouch thermostat
Residential Thermostats
Commercial Thermostats
Explorer IAQ Thermostats
Venstar explorer iaq thermostat
Explorer Thermostats
Venstar explorer thermostat
Explorer Mini Thermostats
Venstar explorer mini thermostat
T2000
T2100
FlatStat Thermostats
Venstar flatstat thermostat
Residential
Hotel
Slimline Thermostats
Venstar slimline thermostat
Residential
Commercial
Small Series Thermostats
Venstar small series thermostat
Residential
Commercial
Value Series Thermostats
Venstar value series thermostat
Programmable
Non-Programmable
ACCESSORIES
Explorer Wi-Fi Module
ACC-VWF2
ACC-VWF2 (Replaces ACC-VWF1) allows thermostat's access over the internet.
Compatible with: T3700, T3800, T3900, T4700, T4800, T4900
Explorer Z-Wave Module
ACC-VZW1
ACC-VZW1 expands the compatibility of your Explorer thermostat with the Z-Wave Plus module. It allows connections to other devices and hubs running on Z-wave technology.
ACCTSENWIFIPRO Wi-Fi Temperature Sensor (Replaces ACCTSENWIFI)
ACCTSENWIFIPRO
Venstar Wi-Fi temperature sensor that allows remote temperature measurement (outdoor, indoor room temperature averaging, supply & return temperature sensing, and walk-in refrigeration & freezing monitoring).
  1. Compatible with ColorTouch: T7850, T7900, T8850, T8900
  2. Compatible with Explorer: T3700, T3800, T3900, T4700, T4800, T4900, T4900SCH
  3. Compatible with Explorer Mini: T2000, T2050
ACC0401 Indoor Sensor
ACC0401
Venstar ACC0401 remote indoor temperature sensor with an override button that offers the user ability to change to an occupied mode for after-hours heating or cooling.
Compatible with: T1100FS, T1700, T1800, T1900, T2700, T2800, T2900 or TSTATEZ
ACC0400 Outdoor Sensor
ACC0400
The sensor allows the outdoor air temperature to be sent to the thermostat.
The high and low outdoor air readouts for the day can be displayed on the T1800, T1900, T2800 and T2900 thermostats.
When used as remote room sensor, the accessory can be used with the Venstar T1800, T1900, T2700, T2900 and T2900SCH.
ACC0402 Duct Sensor
ACC0402
Remote Duct Sensor for Venstar thermostats is a digital temperature sensor with 5 feet long cable.
ACC-DSEN Remote Duct Sensor
ACC-DSEN
Remote duct temperature sensor that may be used as a monitoring sensor or a control sensor,
Compatible with: (When used as a MONITORING sensor) T5800, T5900, T6800, T6900, T7800, T7850, T7900, T8800, T8850, T8900, T3700, T3800, T3900, T4700, T4800, T4900, T4900SCH
Compatible with: (When used as a CONTROL sensor) T5800, T5900, T6800, T6900, T7800, T7850, T7900, T8800, T8850, T8900, T3800, T3900, T4700, T4900, T4900SCH
ACC-TSEN 10K Remote Sensor
ACC-TSEN
Remote temperature sensor that can be used as a monitoring sensor or a control sensor.
This sensor can be used indoors or outdoors.
  1. Compatible with: (When used as a MONITORING sensor) T5800, T5900, T6800, T6900, T7800, T7850, T7900, T8800, T8850, T8900, T3700, T3800, T3900, T4700, T4800, T4900, T4900SCH, all colortouch and 3 Explorer
  2. Compatible with: (When used as a CONTROL sensor) T5800, T5900, T6800, T6900, T7800, T7850, T7900, T8800, T8850, T8900, T3800, T3900, T4700, T4900, T4900SCH, all colortouch Thermostats plus 2 explorer thermostats T3700 and T3800
ACC0414RF Wireless Sensor
ACC0414REC
Wireless Remote Room Sensor that can be used to monitor indoor or outdoor temperature when used in conjunction with ACC0414REC receiver.
ACC0414REC Wireless Receiver
The wireless receiver allows the outdoor air temperature to be sent to the thermostat.
It can be used with the T1100FS, T1700, T1800, T1900, T2700, T2800, T2900 or TSTATEZ thermostats
When used as remote room sensor, the accessory can be used with the Venstar T1900, T2700, T2900 and T2900SCH thermostats.
ACC0430 Humidity Module
ACC0430
Simple, snap-in module that provides humidify/dehumidify control between thermostat and HVAC unit equipped with a humidification/dehumidification system. It displays relative humidity level as measured at thermostat location.
Compatible with: T1800, T2700, T2800, T2900
ACC0410 Add-A-Wire
ACC0410
In applications where additional wiring cannot be run, the Add-A-Wire accessory can be used to add a wire to the thermostat.
  1. Allows 5 wire thermostats to use only 4 wires
  2. Also allows 5 wires to work like 6 wires
ACC0620 Explorer Lock Ring
ACC0620
It prevents the front door on a Slimline thermostat from being opened by unauthorized users.
Compatible with: T1700, T1800, T1900, T2700, T2800, T2900, T2900SCH
ACC0625 Explorer Lock Ring
ACC0625
Venstar ACC0625 prevents the use of the thermostat buttons after it has been installed.
Slimline Door ACC0440
ACC0440
This is a replacement door for Venstar Slimline Platinum series thermostats.
Compatible with: T1700, T1800, T1900, TSTATEZ, T2700, T2800, T2900
TIB515 Interface for Trane Equipment
TIB515
This Interface Board allows any 24VAC thermostat to be connected to applicable Trane Voyager equipment by converting old Trane HVAC systems DC Voltage signals into traditional 24VAC signals.
Compatible with Trane Voyager Units produced from 1991 to mid 2003, the serial number on the units will start with a letter "A-Z" or a number less than "322".
ACC0432 EZ Programmer
ACC0432
The EZ programmer accessory allows the user to quickly transfer the configuration settings from one thermostat to another.
Wireless Module ACC0434
ACC0434
ACC-0434 RF Wireless Module allows additional local thermostats to be connected to the Venstar Comfort Call (ACC0433) Base Station.
ACC0800 Power Supply for Wireless Thermostat
Optional power supply for wireless thermostat, with this accessory the T1100RF wireless thermostat does not need batteries.
Compatible with: T1100RF
Extra-Zone ACC0450
ACC0450
It adds an extra zone for your system to control over or under conditioned areas.
ACC0454 Wi-Fi Key
ACC0454
Venstar ACC0454 Skyport Wi-Fi key allows thermostats to communicate with a Wi-Fi router and be accessible from any PC or using the free Venstar smartphone apps.
Compatible with: T5800, T5900, T6800, T6900
Check out the Venstar and Totaline equivalent models in the article here.
Learn more on HVAC systems and controls in the link here.
Contact our HVAC Controls Engineering team for assistance with custom HVAC control solutions.
