Troubleshooting Common HVAC Problems
HVAC systems make the home comfortable by offering temperature and humidity regulation options. Like any other systems, efficient operation is needed and electrical as well as mechanical issues may occur. Routine maintanance can help prevent breakdown.
Below are some HVAC issues and the troubleshooting tips needed to address the issues.
Noises in the system
  1. Damaged motors
  2. Loose parts
  3. Corrosion within the system
  4. Debris/ forign materials in the ducts
  5. Malfunctioning equipment
  6. Errors during installation or repair
  7. Routine wear and tear
What to inspect
  1. Remove any debris from the ductwork
  2. Lubricate the moving parts
  3. Fasten loose components
Power Issues
  1. Wiring issues
  2. Tripped circuit breakers
  3. Blown fuses
What to inspect
  1. Check to ensure there is no loose connection
  2. Replace blown fuses
  3. Check for tripped circuit breakers
Controller Issues
  1. Wiring Problems
  2. Malfunctioning/ dead batteries
  3. Wrong thermostat settings
  4. Damaged/deffective controller
What to inspect
  1. Inspect and fix wiring issues
  2. Replace the batteries
  3. Ensure the controller's settings are correct
  4. Consider replacing the controller
System Leaks
  1. Routine wear and tear
  2. Malfunctioning equipment
  3. Errors during inspection/ repair
  4. Corrosion
  5. Refrigerant leaks
What to inspect
  1. Check for any errors during installation or repair
  2. Identify and fix refrigerant leaks
  3. Inspect for blockage that need to be cleared from the condensate line
Uneven temperature regulation
  1. Clogged filters
  2. Thermostat issues
  3. Blocked vents and pipes
What to inspect
  1. Service/replace air filters
  2. Unblock blocked vents and pipes
  3. Ensure the thermostat has correct settings
Limited Airflow
  1. Dirty or obstructed air filters
  2. Damaged or blocked ducts
  3. Faulty blower motor
What to fix
  1. Clean or replace air filters
  2. Check for and remove any blockages in the ducts
  3. Arrange for a professional inspection if there are concerns about the blower motor's functionality
It is important to note that not all errors need repair or attention from certified technicians. For those that need attention, the technician can be able to do a diagnosis of the system.
Contact our HVAC Control Engineering team for assistance with custom HVAC control solutions or learn more here.
