Trane Sensors Temperature Averaging
There are two configurations used for temperature averaging:
  1. Setting up a thermostat that reads separate sensors and averages the temperature itself using its software
  2. Wiring sensors in averaging setup, series/parallel
Temperature averaging is possible with Trane sensors. The new Version 5.3 Software release for Wi-Fi thermostat models XL824, XL850, and XL1050 allows multiple temperature sensor averaging for non-zoned systems.
When adding ZSENS930AW00MA wireless temperature sensors to a connected control running version 5.3 software be sure to download the new Installer guide for the ZSENS930AW00MA sensor.
Unlike Controls running on Software Versions earlier than 5.3, the temperatures of the onboard sensor and wireless sensor can be averaged equally without disabling the internal sensor.
Below is the Version 5.3 Sensor Application Matrix.
Trane Temperature Averaging Matrix
THERMOSTAT
On-Board Sensor
ZZSENSAL0400AA
ZSENS930AW00MA
TZONE940
XL824/XL850/XL1050
XL824/XL850/XL1050
XL824/XL850/XL1050
XL824/XL850/XL1050
XL824/XL850/XL1050
XL824/XL850/XL1050
XL824/XL850/XL1050
XL824/XL850/XL1050
XL850/XL1050
XL850/XL1050
XL850/XL1050
XL850/XL1050
XL824/XL850/XL1050
XL824/XL850/XL1050
XL824/XL850/XL1050
XL824/XL850/XL1050
√- Senses temperature from a respective sensor
●- Averages temperature between a specified number of sensors
You can find other HVAC wireless sensors here. Contact an Rfwel HVAC Controls expert for assistance on your next project.
