Top 15 Google Home Compatible Thermostats of 2023
Smart thermostats offer big energy savings as they bring intelligence to your home heating and cooling system. This makes heating more efficient by learning how you like your home warmed thus maximizing comfort while minimizing costs. They provide the luxury of being controlled remotely via smartphone or web apps. Voice control is now a trend with the availability of Amazon Alexa and Google Assistant.
Google Assistant
Below are the top 15 thermostats that work with Google Assistant.
Nest Learning T3007ES Thermostat
Nest Learning thermostat
The Nest Learning Thermostat is known for its intelligent features, sleek design, and seamless integration with Google Assistant. It learns your preferences over time and programs itself based on those preferences. Offers full control via Voice commands or the smartphone app.
Ecobee EB-STATE5-01 Smart Thermostat
EB-STATE5BR-01 - Bryant ecobee 5 Smart Pro Thermostat with Voice Control
It comes with several smart features like occupancy detection enabling it to be more efficient and save energy without compromising on comfort. Its seamless integration with Google assistant for voice controls makes it easy to use.
Honeywell RCHT9610WFSW2003 T9 Smart Thermostat
Comes with a remote temperature, humidity and proximity sensor coupled with voice command capabilities from your Google Home. It is also equipped with geofencing capabilities for more efficient conditioning of your home.
Emerson Sensi ST55 Touch Wi-Fi Thermostat
Emerson's latest budget-friendly smart thermostat lets you control your heating and cooling from afar but doesn't overwhelm you with complicated options or setup procedures. It's the perfect choice for people who want a recent, dependable Wi-Fi thermostat but don't need high-end features.
Emerson Sensi ST75 Wi-Fi Thermostat
If your home or business is large, with multiple rooms that compete for HVAC attention, the Emerson Sensi ST75 is worth a look. It offers in-depth external sensor support with plenty of options for monitoring and managing them and can be controlled fully via voice commands.
Sinope TH1123WF Smart Wi-Fi Thermostat
Though this thermostat is uniquely designed for line-voltage electric heating systems, it offers Wi-Fi connectivity and integrates well with Google Assistant. It is reasonably priced and easy to use and install.
Vine TJ-610E Wi Fi Smart Thermostat
Is designed to support a wide range of scheduling options and with its budget friendly price makes it a good cost saver option. It is also easy to install and relatively easy to use due to its touchscreen display.
Ecobee EB-STATE4-01 Smart Thermostat
Ecobee4 EB-STATE4P-01, Voice Enabled Smart Wi-Fi Thermostat with Room Sensor
It is a smart Wi-Fi-enabled thermostat that comes with a built-in Google Assistant. Through this one can get it to set a timer, read the news, adjust the temperature, among other functions. This thermostat can detect occupancy and automatically enable the right mode on your Ecobee4 for energy savings when it senses no one is home.
Honeywell RCHT8612WF T5+ Smart Thermostat
Comes with geofencing capabilities allowing for more efficient heat and air conditioning for your home. As a plus, it can be controlled by voice commands.
Nest E T4000ESThermostat - This thermostat is very budget friendly with a sleek design and uses machine learning to learn how you like to condition your home and seamlessly integrates with Google Assistant for voice commands.
Honeywell THX321WFS2001W Smart Thermostat
It utilizes the Honeywell app coupled with geofencing capabilities making it ideal for homeowners wanting to prioritize space in their house according to their comfort needs.
Bosch Connected Control BCC100 Thermostat
It is an easy-to-use smart thermostat with phone app and voice control functionality.
Lux Kono KN-S-MG1-B04 Smart Thermostat
The Lux Geo Thermostat has geofencing capabilities for automatic home and away modes and can also set recurring heating and cooling schedule in the related Lux app. The thermostat's flexible design can be mounted either vertically or horizontally.
Saswell Google Home Thermostat
This thermostat comes with a large backlit LCD display compatible with multiple HVAC systems. It can be controlled remotely via the Saswell app with a child lock feature. Works really well through Google Voice Activation.
Check out other wireless thermostat options here.
When choosing a smart thermostat for your home, always consider factors such as heating and cooling stages, compatibility with your indoor unit, C wire requirement, cost and ease of installation and use.
Worried about selecting the best thermostat for your application? Contact our HVAC Controls Engineering team for guidance on custom HVAC control solutions or learn more in the link here.
