240 VAC to 120 VAC Step-Down Streetlight Photocell Power Tap Adapter variants:
In the United States, the common voltages for residential
area streetlight luminaires are single phase 120 or 240V AC. However, some
large-scale luminaire arrays are fed via 3 phase 480V AC giving a phase to
ground voltage of 277V AC for each luminaire.
At Rfwel Engineering’s Power Solutions group, which is
part of our Wireless Infrastructure group, we offer different cost-effective
ways of utilizing the voltage available at the streetlight luminaire to power communication
equipment. One way is through streetlight power tap adapters that install between the luminaire/ streetlight locking receptacle (ANSI C136.41) and the photocontrol device. Photocell power
taps still allow for the normal photocontrol operations while supplying
constant power to streetlight-pole mounted communication equipment. A more
detailed explanation the workings of power tap adapters can be found here.
Rfwel Engineering provides power taps that:
convert 120V AC input to PoE (IEEE 802.3af/ 802.3at) output,
terminated using an RJ45 connector (see examples);
convert 120/ 240 VAC to 12/ 24/ 48 VDC output;
step down any AC voltage up to 480V AC to standard 120 VAC output
(see examples);
provide a constant AC output same as the AC input (see examples)
The FP289A-120-CNB streetlight power tap steps down the 240V AC
availableat the
luminaire to 120V AC without introducing bulky conversion circuitry while
allowing normal photocontrol operation. This can be used, for example, to power pole mount small cell installations with a battery backup
system. Using the FP289A-120-CNB allows for uninterrupted powering of point-to-point
backhaul links, access radios, and associated network equipment
like switches and routers. The power tap choice can also be customized as
needed to vary battery amp hours (Ah) or output voltage to meet the different equipment
load requirements.
Standard Streetlight Power Tap (No Dimming Control)
Another variant
of the same tap FP289A-120-CNB-A also
provides stepped down 120V AC power to ancillary devices from 230/ 240V AC
available at the luminaire. The FP289A-120-CNB-A has 4
additional contacts to allow for pass-through of dimming photocontrol
operations. This variant is compliant with ANSI C136.10 for street and area
lighting and C136.41 for dimming control pass through (7-pin).
Streetlight Power Tap with 4-Dimming Control Contacts
These power taps are typically provided with a 2 SEOOW conductor
16AWG flush cut cable end, however, different custom termination options are
available as captured here to meet the diverse needs of communication and
control installations.
The Power Tap does not provide a ground connection. If the
device requires grounding, other provisions must be made to ensure proper
grounding.
Contact our Power Solutions Specialists to help you configure
the power tap and/or termination that you need for your next project.
