Samsung MIM-B14 External Contact Control Module Installation and Operation
Samsung MIM-B14 module connects to DVM S/DVM S2 outdoor units, DVM S Eco, DVM Chiller, DVM S indoor units, CAC indoor units, FJM multi-zone system indoor units, and Samsung RAC single zone wall unit systems (excluding Novus) for control.  Application areas include hotel key card switch, door/window switch, PIR sensor with timed relay and other occupancy sensors.
It is mounted indoor units that need control or in MAIN outdoor unit (DVM S/DVM S2 Series outdoor units only). In outdoor units it monitors system ON/OFF status, error status, and manually enable night time quiet operation mode.
The module connects directly to indoor or outdoor unit PCB (CN81 and CN83) with included connectors.
Follow the following steps to install the control module:
  1. With screws, secure the PCB case within the indoor unit control box or in the proper location.
  2. Attach the external controller PCB after the PCB casings have been fixed.
  3. Connect a 2 pin wire between the indoor unit PCB EXT_CTRL connection (CN83) and the external controller PCB CN83.
  4. Connect a 4-pin wire between the indoor unit PCB COMP/ERROR and the external controller PCB CN81.
Circuit Diagram for Controlling External Heater (ON/OFF)
Circuit Diagram for Turning ON/OFF Indoor unit (Via External Contact Control)
  1. Dry contact must be connected to the input terminals 5,6.
  2. When controlling external heater, the contacts need to be connected to the load.
    • Related Articles
    • Samsung MIM-H05UN Wi-Fi Adapter Replaces MIM-H04UN
      Samsung has introduced the MIM-H05UN Wi-Fi Adapter which, like the preceding MIM-H04UN allows for DVM S indoor units, single-zone CAC units, and FJM systems with slim duct, cassette and/or console units connected to be remotely monitored and ...
    • Samsung MIM-C02N S-Converter Module for VRF Systems
      Samsung MIM-C02N is a communicating S-Converter module that connects Samsung AC systems to a computer. It's main functionality is to connect the system with test run program. The Samsung MIM-C02N has two primary Test run programs: S-Net Pro: ...
    • Bryant Evolution Connex SYSTXBBECC01-B Control
      Bryant introduces a smart Wi-Fi enabled Evolution Connex system thermostat, SYSTXBBECC01-B. It is 7-day programmable with wake-away-home-sleep and vacation scheduling. With dual-fuel solution that allows furnace and heat pump combinations. In that ...
    • Samsung MIM-H03UN Wi-Fi Adapter for DVM S and CAC Systems Introduction
      Samsung MIM-H03UN Wi-Fi adapter facilitates remote control and monitoring of DVM S and sigle zone CAC systems from a mobile device via Samsung Smart Home app (available on Google Play or iTunes app stores). One adapter is needed for control of CAC ...
    • Samsung MIM-A60UN Replacing TADPT2
      Samsung TADPT2 Third Party Thermostat Adaptor allows control of Samsung HVAC equipment with a 24VAC thermostat. The thermostat adapter must be connected to F1/F2 terminals. It can offer control for up to two indoor units on the same system ...
