Samsung MIM-A60UN Replacing TADPT2
Samsung TADPT2 Third Party Thermostat Adaptor allows control of Samsung HVAC equipment with a 24VAC thermostat. The thermostat adapter must be connected to F1/F2 terminals. It can offer control for up to two indoor units on the same system simultaneously. In such a case, the indoor units are controlled as a group, not individually.
Controlling one indoor unit
Controlling two indoor units simultaneously
MIM-A60UN allows control of one indoor unit with a 24VAC thermostat. MIM-A60UN connects to the F3/F4 wired controller communication line hence it does not need to be installed on/in the indoor unit(s). It supports 1 or 2 stages cooling inputs as well as 1 or 2 stages heating inputs.
*The field-provided (sold-separately) 24VAC transformer required (Samsung multi-position AHU's contain a 24VAC transformer) when connecting both adapters to thermostats can be purchased here
Both the F3/F4 as well F1/F2 adapter versions have the same software.
Central controls such as DMS2, DMS2.5, MIM-H03UN, and MCM-A300N can only monitor indoor units without offering control when using TADPT2 as well as MIM-A60UN.
Here are other HVAC Control Adapters.
For custom HVAC solutions, contact our HVAC Controls Engineering team for assistance or learn more on our HVAC Controls website.
