High Efficiency: Because the SEC-1212P is built with modern switch-mode technology, it is both energy efficient and dependable. This is vital for the APX 8500's long-term functioning, especially in critical situations.
With a universal AC input range of 100 to 240 volts, the SEC-1212P is suitable for a wide range of power grids, making it excellent for global operations, which is a common scenario for APX 8500 users. Connection from the power supply to radio is via the Modular Connector Cable shown below.
Do not connect bare stranded wire end directly to the DC output terminal as the strands will spread out when the set screw is tightened and all the strands may not be pinched firmly under the set screw.
Compact and Durable: The SEC-1212P fits seamlessly in a variety of situations, from control rooms to mobile units, thanks to its tiny size and strong design, complementing the APX 8500's versatility.
Noise Reduction: The ability of the SEC-1212P to eliminate output voltage ripple and RFI is one of its important advantages, guaranteeing that the APX 8500 functions without any power-related interference, which is critical for clear communication.
Safety & Compliance: In communication equipment, safety is vital, and the SEC-1212P's compliance with UL, FCC, and CE standards assures that it is as safe as it is effective.
