RV/ Camper Cellular Amplifier & 3G/ 4G Router
In this generic example, an external antenna (mounted on the RV) picks up the existing cell phone signal and sends it to the amplifier.
Directly attached to a WWAN Router is a 4G data modem. The signal from the antenna passes through a dual-band amplifier before getting to the router. From the 4G LTE or 5G NR router anywhere in the vehicle, one should be able to receive sufficient signal.
See RV antenna and amplifier options here.
Learn more on techniques on how to improve cellular signal.
Contact us for the entire solution and for your custom design based on specific constraints and target specifications.
