Omni-Directional Antenna Connected to USB Modem
Includes a Cellular 4G/5G router and lightning protection. Note that coaxial cable run from roof to modem is 75ft so need high quality (low-loss) cable such as the LMR-400 cable shown but even with this the attenuation is 4.4dB. Therefore need a powerful antenna such as the 9dBi shown to make up for the cable losses. Preferably a higher-gain directional Yagi antenna should be used instead but will require orientation to directional of maximum received signal strength.
Related Articles
MIMO External Antenna Configuration (with Omni-Directional and Directional Panel Antenna) for 4G LTE/ 5G NR Sub 6GHz Application
Shown in this drawing to include a Peplink Multi-WAN router which combines multiple Cellular or other ISP Internet connections for increased bandwidth. For example, if you have multiple LAN clients that need to concurrently upload or download data ...
MIMO External Antenna Configuration (with Omni-Directional and Directional Yagi Antenna) for 4G LTE/ 5G NR Sub 6GHz Application
Shown in this drawing is a Multi-WAN router which combines multiple Cellular or other ISP Internet connections for increased bandwidth. Cellular reception is improved with use of Omni-directional and Directional Yagi antenna. For example, if you have ...
Cellular Direct-connect In-Building Amplifier, with Outdoor Directional Yagi Antenna
Drawing showing an example of a direct-connect bidirectional amplifier connection between a 4G/5G router or modem to a directional antenna to improve indoor cellular reception. The direct attach amp is important for maximum power transfer. Yagi ...
In-Building Signal Solution with RF Bidirectional Amplifier for Large Room Coverage
Solution for weak RSRP reception and improvement of signal coverage in a large room. For various rooms, check solution for DAS. The solution includes an outdoor directional antenna (see option with outdoor omni antenna), lightning protection, BDA, ...
In-Building Signal Solution with RF Bidirectional Amplifier for Large Room Coverage (with Omni Antenna Option)
Solution for weak RSRP reception and improvement of signal coverage in a large room. For various rooms, check solution for DAS. The solution includes an outdoor omni antenna (see option with outdoor directional antenna), lightning protection, BDA, ...
