Mitsubishi Wireless (Wi-Fi) Interface 2 (PAC-USWHS002-WF-2) Setup
Existing Mitsubishi systems can be monitored and controlled remotely via the internet using a smartphone or tablet through the Kumo Cloud app and the PAC-USWHS002-WF-2 Wireless Interface.
PAC-USWHS002-WF-2 Wi-Fi Kit
Note that Mitsubishi's PAC-USWHS002-WF-2 Wireless Interface is only compatible with encrypted 2.4 GHz b/g/n protocols Wi-Fi networks. It cannot be used with 2.4GHz & 5GHz mesh networks. Your router should be able to support 2.4 GHz and b/g/n protocols. So routers configured to support ONLY Wi-Fi 5 (802.11ac), Wi-Fi 6 (802.11ax) or Wi-Fi 6E (802.11ax at 6 GHz) will not work.
You need to confirm the compatibility with your Mitsubishi mini-split from the chart here before making a purchase. Contact us for compatibility questions or router selection should you have challenges confirming the frequency band supported by your router.
PAC-USWHS002-WF-2 can be used together with the MHK2 wireless thermostat simultaneously or as a standalone. It works with both Google Assistant and Amazon Alexa.
Follow the below steps to set up your wireless interface:
  1. Power down all systems (At the unit and circuit breaker)
  2. Remove the cover to gain access to the control board
  3. Connect a Mitsubishi Electric wireless interface to the CN105 connector on the indoor unit board
  4. Return the cover and power up all systems
  5. At this stage, you should now be able to see a steady green light and four quick blue flashes indicating Bluetooth LE configuration mode. The interface is ready to connect using the app. Three slow, blue flashes repeat after the Connection is complete.
  6. Turn on Bluetooth in phone/tablet settings. Log into the 2.4 GHz WiFi network only, if previously logged in to the 5 GHz network, go into your WiFi settings and forget this network.
  7. Download Kumo Cloud App from the App Store, Google Play, or Amazon and install
  8. Go to System Setup, Installer Settings. Enter the 10-digit diamond contractor PIN (Press "Skip" if you are not a diamond contractor). Connect new site or select new site, name site, enter wireless network.
  9. Create an account using your email and create a password
N/B: Factory reset of PAC-USWHS002-WF-2 devices manufactured before June 2022 will prevent setup via Android 12+.
Note that the installation should be conducted by a professional installer to avoid any damage or injury.
Learn more about other HVAC Wireless Interfaces here.
​Contact our HVAC Controls Engineering team for assistance with custom HVAC control solutions or learn more here.
