Shown in this drawing is a Multi-WAN router which combines multiple Cellular or other ISP Internet connections for increased bandwidth. Cellular reception is improved with use of Omni-directional and Directional Yagi antenna.
For example, if you have multiple LAN clients that need to concurrently upload or download data using a cellular connection, you may combine multiple cellular (see more on
dual modem for dual cellular connectivity) connections to improve average speed per client or for redundancy/failover.
Devices supporting MIMO configurations employ special coding on signals from different transmit antennas in multipath propagations to improve signal reception.
For transmit/receive diversity, multiple receive/transmit antennas are used at the receiver/transmit to increase the probability of detecting the signal from a single or multiple transmit/receive antennas. No MIMO-coding is used in this case.
Provide proper separation between the MIMO antennas (or proper isolation of the antennas) to take advantage MIMO or Diversity configs (See more
here)
