Low Voltage Disconnect (LVD) Operations
Low voltage disconnects (LVDs) are a type of voltage disconnect device that are designed to protect batteries from damage due to excessive discharge and sensitive system loads from low battery voltage. Typically, discharging batteries beyond a critical low voltage can damage the batteries and/or load, and require a longer recharge interval. LVDs work by automatically disconnecting the load from the battery when the battery voltage drops to a certain predetermined level.
Connecting LVDs (Negative Ground Model)
LVDs are commonly used in battery-powered applications such as solar power systems, off-grid homes, and RVs. These devices can help extend the life of the battery by preventing over-discharge, which can damage the battery and reduce its overall lifespan. They can also help ensure that critical loads, such as emergency lighting or medical equipment, remain powered even in the event of a power outage.
There are several types of LVDs available, including electronic and mechanical LVDs. Electronic LVDs use microprocessors to monitor the battery voltage and automatically disconnect the load when the voltage drops below a certain threshold. Mechanical LVDs, on the other hand, use a relay or switch to disconnect the load when the battery voltage drops.
Overall, LVDs are an important component in many battery-powered applications, helping to protect equipment and extend battery life. They are available in 12, 24 and 48V DC models as per your system needs.
For your customized power solution contact an Rfwel Power Solutions specialist here.
    • Related Articles
    • Selecting a suitable Low Voltage Disconnect (LVD)
      When selecting a low voltage disconnect (LVD) for a battery-powered application, there are several factors to consider. Some of the most important considerations include: Low Voltage Disconnect (LVD) Voltage threshold: The voltage threshold is the ...
    • Streetlight Power Tap Operations Basics
      Power Tap Basics A power tap allows the use of existing light pole infrastructure to power auxiliary equipment like wireless access points, CCTV cameras, sensors, routers, and gateways etc. It taps into the power supply of a streetlight by connecting ...
    • Digital Loggers LPC9 Pro Web Power Switch and Control Unit Operations
      The Digital Loggers LPC Pro Switch is a network-enabled power switch that allows you to remotely control the power to your devices. Using a simple web interface (accessible from any browser), it allows you to AutoPing and reboot connected devices ...
    • 240V to 120V AC Streetlight Power Tap Adapter for Public Cameras (Case of Pelco)
      The world over, streetlights are transcending their traditional role of illumination. They have been put to use by many cities and municipalities, supporting several smart city initiatives like traffic surveillance cameras and public Wi-Fi access ...
    • Solar Powered Remote Video Surveillance 2
      Example solution to monitor remote sites such as construction sites, utility installations or other areas where no power exists (and outside range of power-over-ethernet use). Sample system includes all the components: Solar PV system (solar modules, ...
