Coaxial Cables Lightning Protection
Nearby lightning strikes usually generate a short duration high current (thousands of Amps) pulses. These impulses contain components with very diverse frequency ranges i.e., both low and high frequency. Typically, the VHF and UHF components can be picked by outdoor communication antennas leading to generation of very high voltages and currents.
Fig 1: Gas Discharge Tube Lightning Protection Device
Generally, the strike creates a potential difference between the center conductor and the cable shielding of the coaxial cable. This then forces a high voltage differential and damaging current flow through the equipment. A lightning surge protector is therefore needed to shunt this very high current to the ground without transferring it to the connected devices.
Fig 2: Connecting LSPD to the Coax cabling
It is important to note that these are not direct strike devices but only handle the effects of nearby strikes. In the event of a direct strike your protection device would most likely be permanently damaged.
What to consider for Coaxial Lightning Surge Protector Devices (LSPDs):
·           1.  RF Performance
This covers the operational frequency, insertion loss and VSWR. These parameters will indicate what portion of the transmitted signal will reach the output and what portion would be lost during transmission. The goal is to keep the losses low, thus low values of VSWR and IL are ideal. Typically, the surge protector primarily operates as a passive component during most of its lifetime only coming into action in the event of surges.
·            2.   Connector type (for instance N, TNC, SMA etc.)
In most cases protectors offer bidirectional protection, meaning you can reverse inputs and outputs without affecting operation. Connectors bring different designs for both the inner and outer conductors; usually the outer conductor has a significantly greater current capacity than the center pin to help dissipate the surge current. The current rating of most center pins is rated as the survivability of ten 8x20μs ampere pulses.
Connector Type
TNC
BNC
SMA
UHF
Pin Diameter
0.12”/3.1
0.08”/2.1mm
0.08”/2.1mm
0.05”/1.3mm
0.19”/4.8mm
Transient Current Capacity (Higher limit)
30kA
20kA
20kA
5KA
50kA
Transient Current Capacity (Lower limit)
10kA
5kA
5kA
2.5kA
10kA
Table 1
Of these connectors, each has an inherent maximum voltage, current, and RF power limitations due to the physical design and materials used.
·               3. DC pass/ DC block protector
Indicates whether the connector allows or blocks DC power to equipment alongside the RF signal. If equipment is to be powered, you need DC power through the center pin of the COAX cable to connected devices.
·               4. Type of technology
There are two dominant technologies in surge protection:
Gas Discharge Tubes (cost effective and very common, derate over time usually about 5 years; can build static electricity over time which can cause equipment damage when discharged)
Fig 3: Replaceable Gas Discharge Tube with Screwable Unit to Secure onto LSPD
Coil inductor (offer reliable protection to surges, do not degrade over time but need replacement with significant lightning strikes, no static build up, usually more expensive than GDTs)
·             5.  Type of Mount and connection to grounding:
Configuration of the protector can be used to make it easier to mount, connect and ground successfully. The connection to ground must also be perfect to ensure all the harmful surges are passed to ground. For outdoor applications waterproof units with rubber seals are required.
Simply put when selecting a LSPD go for one with the:
  1. Lowest insertion loss and VSWR for the frequency of operation
  2. Largest recommended connector type for longer service
  3. Maximum Transient Current Capacity so as to carry the highest possible spikes in currents
  4. Best Bi-directional Protection Level
  5. Convenient mount and connection to ground depending on location of installation.
 For more information and custom design solutions for protecting your wireless networks contact us here or give us a call on +1 480 218 1877 or +1 410 877 6887.
    • Related Articles
    • RF performance metrics to consider when selecting a Coaxial Surge Protector
      Coaxial cable lightning surge protectors play a crucial role in safeguarding RF circuits from harmful surges and ensuring optimal signal transmission. They are designed to seamlessly allow the passage of desired RF signals with minimal loss or ...
    • DC Block and DC pass Coaxial Surge Protectors
      DC Block and DC pass Coaxial Surge Protectors In the event of a power surge, there are a few things that need to happen to excess/ unwanted energy. First, the surge needs to be directed to ground as quickly and easily as possible through the earth ...
    • Coaxial Lightning Protection and Signal Quality Issues
      For wireless communication sites with antenna installations, a common issue of concern is whether adding an ethernet/ coaxial surge protector would lead to performance degradation within the system. The questions asked are whether it's actually worth ...
    • Bias Tee DC Injectors
      A bias tee DC injector is a three-port Radio Frequency (RF) device whose primary function is to supply DC power to connected RF devices. It does this without affecting the RF signal or RF performance of the network. It essentially combines two ...
    • Solar Powered Remote Video Surveillance 1
      Describes a means of powering your remote video monitoring equipment and wireless backhaul via solar. Solution may be customized for different cameras, different loads, different ranges (up to several miles even > 50 miles), portability, different ...
