Ion zoning systems have been designed for control and operation of select models of compatible fan coils, variable speed furnace and other hvac communicating equipment.
Consider the image below for carrier's Ion Infinity zoning system with its various components:
Carrier's Infinity Zoning System
The Ion zoning system can include:
- Damper control module
SYSTXCC4ZC01
SYSTXCCRRS01
- Ion TM system control
The Ion Zoning System is controlled using duct static pressure measurements. Communicating two-stage gas furnaces that use PWM ECM blower motors do not support static pressure measurement and are, therefore, not compatible with the Ion Zoning System. For these furnaces, use the Observer Zoning System instead.
Not all observer system accessories are compatible with the Ion Zoning system (except for some dampers)
SYST0101RM
- Ion zone sensors
SYSTXIIRRS01
- Modulating Dampers
ZDAMPREC, ZDAMPRND, or DAMPSL
You can pair Ion(TM) system control with Ion zoning control to create up to 8 controlled zones. For Zones 5-8, a second damper control module must be applied/connected.
Contact our HVAC Controls Engineering team for any assistance with zoning systems or other HVAC control solutions.
