In-Building Signal Solution with RF Bidirectional Amplifier for Large Room Coverage
Solution for weak RSRP reception and improvement of signal coverage in a large room. For various rooms, check solution for
DAS.
The solution includes an outdoor directional antenna (see option with outdoor omni antenna), lightning protection, BDA, indoor
dome antenna, and low-loss cables with appropriate
connectors. The drawing attached is specific for 1900MHz. For other carriers, if multi-band cellular BDA is used, use appropriate multi-band outdoor
yagi antenna and indoor dome antenna.
4G LTE or
5G NR router anywhere in the room should be able to receive sufficient signal propagated from the the dome antenna.
Related Articles
In-Building Signal Solution with RF Bidirectional Amplifier for Large Room Coverage (with Omni Antenna Option)
Solution for weak RSRP reception and improvement of signal coverage in a large room. For various rooms, check solution for DAS. The solution includes an outdoor omni antenna (see option with outdoor directional antenna), lightning protection, BDA, ...
In-Building Signal Solution with RF Bidirectional Amplifier with Distributed Antenna System for Various Rooms
Solution for weak RSRP reception and improvement of signal coverage in different rooms. The solution includes an outdoor antenna, lightning protection, BDA, indoor dome antennas, Splitter (if BDA has only one output port to the indoor antenna ...
Cellular Direct-connect In-Building Amplifier, with Outdoor Directional Yagi Antenna
Drawing showing an example of a direct-connect bidirectional amplifier connection between a 4G/5G router or modem to a directional antenna to improve indoor cellular reception. The direct attach amp is important for maximum power transfer. Yagi ...
Cellular Direct-connect In-Building Amplifier, with Outdoor Omni-directional Antenna
Drawing showing an example of a direct-connect bidirectional amplifier connection between a 4G/5G router or modem to an omnidirectional antenna for better cellular reception for indoor use. The direct attach amp is important for maximum power ...
RSRP Cellular Signal guide
Cellular Signal Guide Cellular end-user devices on a cellular network depend on signal parameters for them to communicate effectively with the cellular towers. Signals from these distribution points or towers face interferences on the propagation ...
