Energy-Efficient Parking Lot Lighting with WALI Wireless Area Lighting Interface
Wireless
Area Lighting Interface by Sunrise Technologies
WALI Nodes on Parking Lot Lightings Managing the lighting in a parking lot can be challenging.
You want safety and visibility for visitors, energy efficiency to reduce costs,
and a system that is flexible, reliable, and easy to control. That’s where the
Wireless Area Lighting Interface (WALI) comes in; a solution designed to give
you full control over your outdoor lighting network.
Why Traditional Parking Lot Lighting Falls Short
Many parking lots still rely on dusk-to-dawn timers or
simple on/off switches. This approach often leads to:
Lights
running when no one is present, wasting energy
Uneven
or insufficient illumination creates safety concerns
Difficulties in monitoring or adjusting fixtures remotely
Higher
maintenance costs due to stress on lamps and relays
How WALI Solves Your Parking Lot Lighting Challenges
WALI Node
This combination gives you full control, so your parking lot
is lit only when it needs to be, reducing energy costs while maintaining
safety.
Key Benefits for Parking Lot Owners
Energy
Efficiency: Motion-based dimming and schedules reduce electricity usage
Enhanced
Safety: Lights brighten when needed, ensuring visibility for pedestrians
and drivers
Lower
Maintenance Costs: Reduced stress on lamps and remote monitoring prevents
unnecessary replacements
Dark-Sky
Friendly: Complies with environmental guidelines, reducing glare and light
pollution
Scalable:
Perfect for small lots or multi-site campuses with hundreds of fixtures
WALI is more than just a control system—it’s a complete
parking lot lighting solution that helps you save on electricity bills, improve
security and visibility, maintain environmental compliance, and easily manage
your lights from anywhere.
Related Articles
RV Park Wi-Fi Solution: Powering Ruckus Wireless Access Points using POE Power from Streetlights
Buy Streetlight/ Light Pole Power Tap Adapters: Recreational Vehicle (RV) parks in the United States are increasingly seeking new solutions to improve efficiency and sustainability, while offering users a more modern, safe and connected experience. ...
Understanding Photocontrols and How to Test them Efficiently
Photocontrols are small, light-sensitive devices that automatically switch lights ON at dusk and OFF at dawn. This automation ensures energy efficiency, safety, and convenience by aligning lighting schedules with natural daylight. In modern ...
Security Cage for Photocontrols – Theft Deterrent Solution
When deploying auxiliary power, IoT devices, cameras, or wireless access points on street-light poles, installers often use a power-tap - a plug-in adapter that fits between the photocontrol receptacle and the luminaire. This configuration draws ...
Custom Power Taps with Equipment Enclosure and Multi - Tap Transformer
For your custom power taps with equipment enclosure and multi - tap transformer, here are some of the common variants which would have a wide application: 5970-70B6-120-120 (150W, 7 pin, includes dimming control, 120V AC out) 5970-7DB6-120-120 (150W, ...
Streetlight Power Tap Operations Basics
Power Tap Basics A power tap allows the use of existing light pole infrastructure to power auxiliary equipment like wireless access points, CCTV cameras, sensors, routers, and gateways etc. It taps into the power supply of a streetlight by connecting ...
