Based on the thermostat model, you may need the "C-Wire" (Common Wire).
System | Sensi Lite | Sensi Smart | Sensi Touch | Sensi Touch 2 |
Heat Only | Yes (3) | Yes (3) | Yes (3) | Yes (3) |
Cool Only (AC) | Yes (3) | Yes (3) | Yes (3) | Yes (3) |
Conventional Heating & Cooling | Yes (1) | Yes (2) | Yes (3) | Yes (3) |
Heat Pump/ Geothermal | Yes (1,3) | Yes (3) | Yes (3) | Yes (3) |
Humidifiers/Dehumidifiers | No | Yes | Yes | Yes |
Communication/ Proprietary System | No | No | No | No |
Millivolt | No | No | No | No |
Line Voltage | No | No | No | No |
RV/ Camper Applications | No | No | No | No |
Conventional Heating and Cooling Systems
- Gas/Oil/Propane Furnace
- Boiler/Radiant
- Air Conditioner
- Electric Furnace
Heat Only Systems:
- Electric Furnace
- Boiler/Radiant
- 1- Compatible with multi-stage systems up to 1H/2C or 2H/1C
- 2- "C-Wire" required for HomeKit compatibility
- 3- "C-Wire" required
Incompatible Systems:
- Communication/ Proprietary System
- Line Voltage Systems (generally 110V/220V baseboard heating)
- 12VDC (RV/campers) Applications
- Stranded Wiring
See the article in the link
here for more information on Emerson Sensi thermostats
Learn more on HVAC systems and controls in the link
here.
