200 Series Coaxial Cable Typical Attenuation in dB | |||||||||||||||
| Frequency (Application) | 10 ft | 20 ft | 50 ft | ||||||||||||
| Low-Band Cellular (600MHz, Band 71) | 0.9 | 1.8 | 4.5 | ||||||||||||
| 900MHz ISM (LoRaWAN, Helium, etc.) | 1.2 | 2.2 | 5.5 | ||||||||||||
| Mid-Band Cellular (1900Mhz PCS) | 1.7 | 3.3 | 8.1 | ||||||||||||
| 2.4GHz (WiFi 4) | 1.9 | 3.7 | 9.2 | ||||||||||||
| 3.5Ghz (C-Band, CBRS) | 2.3 | 4.5 | 11.2 | ||||||||||||
| 5GHz (Wi-Fi 5/6) | 2.8 | 5.5 | 13.5 | ||||||||||||
| 6Ghz (Wi-Fi 6E) | 3.1 | 6.1 | 14.9 | ||||||||||||
400 Series Coaxial Cable Typical Attenuation in dB | |||||||||||||
| Frequency (Application) | 20 ft | 50 ft | 100 ft | ||||||||||
| Low-Band Cellular (600MHz, Band 71) | 0.7 | 1.8 | 3.5 | ||||||||||
| 900MHz ISM (LoRaWAN, Helium, etc.) | 0.9 | 2.2 | 4.4 | ||||||||||
| Mid-Band Cellular (1900Mhz PCS) | 1.4 | 3.3 | 6.5 | ||||||||||
| 2.4GHz (WiFi 4) | 1.6 | 3.7 | 7.4 | ||||||||||
| 3.5Ghz (C-Band, CBRS) | 1.9 | 4.6 | 9.1 | ||||||||||
| 5GHz (Wi-Fi 5/6) | 2.3 | 5.6 | 11.1 | ||||||||||
| 6Ghz (Wi-Fi 6E) | 2.6 | 6.2 | 12.3 | ||||||||||
600 Series Coaxial Cable Typical Attenuation in dB | |||||||||||||
| Frequency (Application) | 100 ft | 150 ft | 200 ft | ||||||||||
| Low-Band Cellular (600MHz, Band 71) | 2.3 | 3.4 | 4.5 | ||||||||||
| 900MHz ISM (LoRaWAN, Helium, etc.) | 2.8 | 4.2 | 5.6 | ||||||||||
| Mid-Band Cellular (1900Mhz PCS) | 4.3 | 6.3 | 8.4 | ||||||||||
| 2.4GHz (WiFi 4) | 4.9 | 7.2 | 9.6 | ||||||||||
| 3.5Ghz (C-Band, CBRS) | 6.0 | 9.0 | 12.0 | ||||||||||
| 5GHz (Wi-Fi 5/6) | 7.4 | 11.1 | 14.8 | ||||||||||
| 6Ghz (Wi-Fi 6E) | 8.3 | 12.4 | 16.5 | ||||||||||
Characteristic impedance (Should match with impedance of other network components).
Frequency of application as it determines the attenuation of your signal, the higher the frequency the higher the attenuation.
Operational power handling capabilities
Voltage Standing Wave Ratio (VSWR)
Environmental conditions (Determines the level of cable flexibility, shielding & cladding material etc.)
Noise handling (The symmetry of signal and returning current carrying conductors cancels, to first order, all effects of external electromagnetic fields. Any residual susceptibility in a coaxial cable results from imperfections in its shield)
Phase Delay (Time delay for each frequency component)
