Clearwire's TD-LTE in the 2.5-2.7GHz Band gets a boost from the Chinese
Announcement this week that the Chinese government is backing the use of 2.6GHz band for TD-LTE by allocating spectrum for this, a big deal for Clearwire because this will very likely lead to economies of scale that will bring equipment cost down – but not sure what good that will do if main equipment vendor is ZTE or Huawei given the Congressional committee’s scathing comments last week.
Huawei Technologies Co. Ltd. and ZTE Corp., China’s two biggest makers of telecommunications equipment, are facing intense scrutiny thanks to a US House Intelligence Committee report, the result of an 11-month fact-finding mission. The crux of the recommendation is the two companies’ failure to provide documents that detail their relationships, and regulatory interaction with Chinese authorities. Presumably, the fear is that Huawei and ZTE could somehow build backdoors into their routers and switches, leaking sensitive information to the Chinese government.
Advantages of LTE TDD vs FDD include:
  • Lower hardware cost because diplexer not needed. Needed in LTE-FDD because of use of paired spectrum.
  • Channel propagation is the same in the uplink and downlink path because of use of the same frequency making channel tuning easier.
  • Possible to dynamically change the UL and DL capacity ratio to match demand (by assigning different width time slots).
  • Advantage to China is that this is a natural upgrade path from TD-SCDMA which also uses unpaired spectrum.
Disadvantages:
  • Unlike in LTE-FDD where guardband already provided to ensure isolation between UL and DL, in LTE-TD need to provide this guard interval and a larger guard interval required if distances are increased (because of longer propagation times) which could affect capacity.
  • Discontinuous transmission which can degrade the performance of the RF power amplifier in the transmitter.
  • eNodeB’s need to be synch’d with respect to the UL and LD transmission time slots to avoid cross-slot interference. If other eNodeB’s use different UL and DL assignments, and share the same CH, then interference may occur between cells.
    • Related Articles
    • The C-Band Spectrum
      Spectrum, the medium on which wireless communication relies, is a very important resource, and a scarce one when it comes to 4G, 5G, and other wireless technologies like TVWS and Wi-Fi. Just recently, C-Band actioning saw about half a dozen companies ...
    • Extending Range of local WiFi Using a High Gain Directional Panel Antenna and Long Range USB WiFi adapter.
      Describes a means of connecting your remote device (for instance a PC) to a fixed 802.11n/ac/ax WiFi network. The main WiFi access point is assumed to be located some distance away thus giving poor Tx/ Rx reception for client PC. The Omni antenna is ...
    • TV White Space Applied in Rural Broadband Wireless Communication
      TV Whitespace (TVWS) radios are being deployed in rural communities by ISPs to provide broadband services. Radio wave propagation at 470 -698 MHz (United States) and 470 - 786 MHz (Global) favors NLOS communications. The 900 MHz, 2.4 GHz & 5 GHz and ...
    • Fixed Wireless Access Developments
      With Cellular operators pushing the reach of 5G mmWave, we could see the application of 5G even in rural areas as opposed to urban areas only. Due to its propagation characteristics, mmWave has been known for short signal reach hence only suitable ...
    • Newly opened up white-space spectrum to enable a plethora of new wireless application
      The beauty of the spectrum between existing TV bands around 50MHz to 700MHz is indoor penetration possibility. The FCC in allowing the use of this spectrum for unlicensed devices also allocated two channels nationwide for wireless microphones who ...
