The drawing shows improvement of cellular signal using a directional antenna. This requires that the antenna be oriented to the direction of maximum received signal strength. You can use Omni-directional antennas for situations where signal reception is not specific.
Solution also includes a Wi-Fi signal improvement solution with a dome antenna.
