Bryant Legacy Thermostats Wiring
There are four legacy series of Bryant thermostats:
- Programmable for AC units
- Non-programmable for AC units
- Programmable for heat pump units
- Non-programmable for heat pump units
For example, T2-PAC01-A and T2-NAC01-AC are for AC systems to control one stage of cooling and one stage of heating and they will not operate a heat pump. T2-PHP01-A and T2-NHP01-A are designed for heat pump systems, to control two stages of cooling and three stages of heating (they can also be converted to AC operation).
An AC system requires up to 6 wires for 24 VAC operation (5 for battery operation alternative). The heat pump system requires up to 7 wires for 24 VAC operation (6 for battery operation)
See below wiring for some of the various systems with the Bryant legacy thermostats:
- Single speed AC to thermostat
common wire not necessary if using battery
Separate Rh and Rc connection (remove jumper) if using split transformer connection for indoor and outdoor unit
- Single speed Heat Pump to thermostat
- Single stage AC and Furnace system to thermostat
The above shows a system with split power (no Rc/Rh jumper in this case).
- 2-stage AC system with variable speed, step modulating, multi-stage and single stage furnace
- 2-Stage Heat pump with Variable speed, Multi-stage, Stage Modulating and Single-Stage Furnace
- FV/FK Fan coil with 2-Stage AC
- FV/FK Fan coil with 2-Stage Heat Pump
It is always ideal to do all wiring when power is disconnected. Refer to device's manual in case wiring is unclear.
Related Articles
PAC-US446CN-1 Replacement Guide: Upgrading from PAC-US445CN-1 & PAC-US444CN-1
The PAC-US446CN-1 Thermostat Interface is the latest evolution in Mitsubishi Electric’s lineup of third-party thermostat adapters. Designed to replace both the PAC-US445CN-1 and PAC-US444CN-1, this updated interface expands functionality, improves ...
Mitsubishi Electric Trane PAC-US445CN-1 Thermostat Adapter
Mitsubishi Electric introduced the PAC-US445CN-1 Thermostat Adapter which, like the preceding PAC-US444CN-1, allows a field-supplied 24V thermostat to control Mitsubishi mini-split indoor units through the CN105 connector and CNH02 connector for ...
When the thermostat doesn't reach the set temperature, what should I do?
In case the temperature in your house or office is not what you selected as the desired temperature from your thermostat, your thermostat/ HVAC system may be malfunctioning. Your thermostat might occasionally have technical issues, just like any ...
Wiring a Thermostat
Thermostats are the control hub for heating, ventilation and cooling systems. They provide access and control from a centralized location making it an important asset of the system. This makes knowledge of their wiring vital for any homeowner. Before ...
Wireless Modbus Applications
In modern building management systems, integrating wireless communication with existing wired devices such as controllers, thermostats, and sensors can significantly enhance system connectivity. This is particularly relevant for devices using Modbus ...
