Antenna Solutions for Public Safety/Emergency Response
Vehicle antennas are designed to provide reliable reception and transmission while mobile. They include whip antennas, shark fin antennas (streamlined antennas), or other low-profile fixed antennas.
Vehicle antennas for public safety/emergency response can have the following characteristics:
  1. Usually support cellular, Wi-Fi, and GPS, and sometimes Bluetooth.
  2. Depending on design, they can be mounted on roof of car, dashboard, fender, or windshield.
  3. Compact design.
See the diagram below for an illustration of different antenna styles ( Click on the names on the picture or inline to learn more: hole mount antennas , dash mount antennas , nmo mount antennas , and coil/spring antennas).
Illustration for various vehicle antennas and their possible mounting positions
NMO Mount Antennas Hole Mount Antennas Dash Mount Antennas
Here are the 3 best vehicle antennas in the market:
1. Laird Multiband Phantom Antenna ( TRA6927M3NB-001 )
  1. Wide band antenna for various wireless applications (698 - 2700 MHz).
  2. Offers up to 5.5 dBi gain.
  3. Features NMO connector type (consider this NMO mounts:  GB8USMI or LBMB8NSI )
2. Trigger 5-Port Under-Dash Antenna ( VPJ69595B-92FAK )
  1. Wide band antenna (698 - 5900 MHz).
  2. Has good gain, 5dBi.
  3. Has Fakra connectors/cables  with 5 antennas ideal for vehicle applications.
  4. Ideal for vehicle under-dash locations mounted to ventilation ducting.
3.  Cellular, GPS, LTE, Wi-Fi  Shark fin Antenna ( GPSDM7002500FFS )
  1. Antenna with multiple applications - includes 3 enclosed antennas.
  2. Easily mounted through a single 3/4" hole.
  3. IP-65 protection/enclosure ensures durability and reliability.
Generally, depending on the characteristics of a vehicle and the intended use, consider the following major factors when choosing an antenna for a vehicle:
  1. Frequency of operation
  2. Antenna gain
  3. Mounting style
  4. Connector types depending on the radio/router.
See the table below for various vehicle antenna comparisons and their key specifications:
Compare Vehicle & RV Antenna Specs
Item Key Specifications Available at these Online Market Places
Laird Technologies  VPJ69595B-92FAK
VPJ69595B-92FAK image
Type:  4G LTE Antenna, 5G NR Antenna, GPS Antenna, Wi-Fi Antenna, Vehicle & RV Antenna
Frequency:  698 - 5900 MHz
Gain:  5 dBi
Connectors:  FAKRA Female (Jack), FAKRA Female (Jack), FAKRA Female (Jack), FAKRA Female (Jack), FAKRA Female (Jack)
buy VPJ69595B-92FAK from RFWEL Engr E-Store
Pulse/ Larsen  GPSDM700-5800GGT  (MPN: GPSDM700/5800GGT)
GPSDM700-5800GGT image
Type:  4G LTE Antenna, GPS Antenna, Vehicle & RV Antenna, Wi-Fi Antenna, 5G NR Antenna
Frequency:  698 - 5875 MHz
Gain:  6.5 dBi
Connectors:  SMA-Male, RPSMA-Male, SMA-Male
buy GPSDM700-5800GGT from RFWEL Engr E-Store
buy GPSDM700-5800GGT from eBay
Rfwel Infra  TRP-20INT-3-B
TRP-20INT-3-B2 image
Type:  Wi-Fi Antenna, Vehicle & RV Antenna, 4G LTE Antenna, 5G NR Antenna, CBRS Antenna (3.5 GHz)
Frequency: 617 - 5950 MHz
Gain:  7 dBi
Connectors:  SMA-Male, SMA-Male, SMA-Male
Mobile Mark  LTM501-3C3C3C3C2C-BLK-180
LTM501-3C3C3C3C2C-BLK-180 image
Type:  4G LTE Antenna, Wi-Fi Antenna, GPS Antenna, Vehicle & RV Antenna, 5G NR Antenna
Frequency:  694 - 6000 MHz
Gain:  5 dBi
Connectors:  SMA-Male, SMA-Male, SMA-Male, SMA-Male, SMA-Male
Laird Technologies  TRA806/17103P
Type:  4G LTE Antenna, 5G NR Antenna, 900 MHz Antenna, Vehicle & RV Antenna, Wi-Fi Antenna
Frequency:  806 - 2500 MHz
Gain:  6 dBi
Connectors:  N-Female
Mobile Mark  RM-WLF-1C-BLK-12
RM-WLF-1C-BLK-12 image
Type:  4G LTE Antenna, Vehicle & RV Antenna, 5G NR Antenna
Frequency:  694 - 2700 MHz
Gain:  3 dBi
buy RM-WLF-1C-BLK-12 from RFWEL Engr E-Store
buy RM-WLF-1C-BLK-12 from Walmart
buy RM-WLF-1C-BLK-12 from eBay
Laird Technologies  VQJ69595B-92VC1
VQJ69595B-92VC1 image
Gain:  5 dBi
Connectors:  SMA-Male, SMA-Male, RPSMA-Male, SMA-Male
buy VQJ69595B-92VC1 from RFWEL Engr E-Store
Laird Technologies  TRA6927M3NB-001
TRA6927M3NB-001 image
Type:  Wi-Fi Antenna, 4G LTE Antenna, 5G NR Antenna, 900 MHz Antenna, Vehicle & RV Antenna
Frequency:  698 - 2700 MHz
Gain:  5.5 dBi
Connectors:  NMO
buy TRA6927M3NB-001 from RFWEL Engr E-Store
buy TRA6927M3NB-001 from Amazon
buy TRA6927M3NB-001 from Walmart
buy TRA6927M3NB-001 from eBay
Mobile Mark  LTM501-3C3C3J3J2C-BLK-180
LTM501-3C3C3J3J2C-BLK-180 image
Type:  4G LTE Antenna, Wi-Fi Antenna, Vehicle & RV Antenna
Gain:  5 dBi
weBoost  304415
304415 image
Frequency:  700 - 2270 MHz
Gain:  3.5 dBi
buy 304415 from RFWEL Engr E-Store
Pulse/ Larsen  GPSDM700/2500SSS
Gain:  6.5 dBi
Cradlepoint  170654-000
170654-000 image
Type:  4G LTE Antenna, GPS Antenna, Vehicle & RV Antenna, Wi-Fi Antenna, 900 MHz Antenna
Frequency:  698 - 3500 MHz
Gain:  5.9 dBi
Wilson Electronics  311125
311125 image
Type:  Vehicle & RV Antenna, 4G LTE Antenna, 5G NR Antenna, 900 MHz Antenna
Frequency:  700 - 1990 MHz
Gain:  5.5 dBi
buy 311125 from RFWEL Engr E-Store
Pulse/ Larsen  SLPT698/960NMO
Type:  4G LTE Antenna, 900 MHz Antenna, Vehicle & RV Antenna
Frequency:  698 - 960 MHz
Gain:  3.3 dBi
Connectors:  NMO
PCTEL  BMAX7633S
BMAX7633S image
Frequency:  760 - 870 MHz
Gain:  3 dBi
buy BMAX7633S from RFWEL Engr E-Store
buy BMAX7633S from Amazon
buy BMAX7633S from Walmart
Pulse/ Larsen  GPSDM7005800SSS  (MPN: GPSDM700/5800SSS)
GPSDM7005800SSS image
Gain:  6.5 dBi
buy GPSDM7005800SSS from RFWEL Engr E-Store
buy GPSDM7005800SSS from Amazon
buy GPSDM7005800SSS from eBay
Mobile Mark  SMD35003C3CWHT180
SMD35003C3CWHT180 image
Type:  4G LTE Antenna, Wi-Fi Antenna, CBRS Antenna (3.5 GHz), 5G NR Antenna, Vehicle & RV Antenna
Frequency:  2100 - 3800 MHz
Gain:  4 dBi
buy SMD35003C3CWHT180 from RFWEL Engr E-Store
buy SMD35003C3CWHT180 from Amazon
Laird Technologies  VPJ69595B-92VC1
VPJ69595B-92VC1 image
Gain:  5 dBi
Connectors:  SMA-Male, SMA-Male, RPSMA-Male, RPSMA-Male, SMA-Male
buy VPJ69595B-92VC1 from RFWEL Engr E-Store
Pulse/ Larsen  SLPT698/2170DMN
Gain:  4.81 dBi
Panorama Antennas  LGMM-7-27-24-58
LGMM-7-27-24-58 image
Type:  4G LTE Antenna, GPS Antenna, Vehicle & RV Antenna, Wi-Fi Antenna, 5G NR Antenna, 900 MHz Antenna
Frequency:  698 - 6000 MHz
Gain:  5 dBi
Connectors:  SMA-Male, SMA-Male, FME-Female, SMA-Female, SMA-Female
buy LGMM-7-27-24-58 from RFWEL Engr E-Store
Mobile Mark  ECOS6-3500DN-BLK
ECOS6-3500DN-BLK image
Type:  4G LTE Antenna, Vehicle & RV Antenna, CBRS Antenna (3.5 GHz)
Frequency:  3500 - 3700 MHz
Gain:  6 dBi
buy ECOS6-3500DN-BLK from RFWEL Engr E-Store
For help on signal improvement,  contact  an RFWEL wireless specialist.
