Airzone Integration Solutions - Google/Alexa
Airzone products that can work with Google Assistant or Amazon Alexa include:
  1. Aidoo Pro (e.g select Mitsubishi's Models Aidoo Controller AZAI6WSPMEL)
  1. Aidoo Wi-Fi (e.g select Fujitsu's Models Aidoo Controller AZAI6WSCFU2)
  1. Webserver hub Airzone (AZX6WSPHUB)
  1. Webserver Airzone Cloud (AZX6WSC5GER)
To set up Google Assistant, follow these steps:
  1. Access the Google Home App and the main window press the  add button .
  2. Configure device .
  3. Select  Works with Google .
  4. Look for  Airzone Cloud .
  5. Once selected, log in with your Airzone Cloud username and password and authorize the Airzone devices found to be added.
When the detection is finished, you will have your Airzone zones available in the main view of the App.
You can try commands such as: OK Google, (turn on/off) the (ZONE_NAME), or OK Google, (go up/down) the temperature of the (ZONE_NAME) 2 degrees.
To control all the zones of your Airzone system at the same time, you can set up Routines by going to:
Google Home app>>More settings/settings>>Click on Assistant>>Routines
To set up Amazon Alexa, follow these steps:
  1. Access the Amazon Alexa App and in the drop-down menu click on Skills and Games .
  2. In the search engine, search for Airzone Cloud , select it and allow its use .
  3. Access with your Airzone Cloud username and password and authorize Alexa to access your Airzone Cloud account.
  4. Click on Discover devices .
When the detection is finished, you will have your Airzone zones available in the devices section, under the thermostats category.
Just like in the Google assistant, you can try the commands, start with Alexa, turn on/off the (ZONE_NAME).
For Amazon Alexa, to control all the zones of your Airzone system at the same time, you can set up Routines by going to:
Alexa app>>Menu>>Select Routines>>Click upper right circle with the plus>>edit the (When)>>click add action>>click Devices and add the zones you want to manipulate>>save
Contact our HVAC Controls Engineering team for assistance in case of any HVAC queries or solution required.
